1999 Dodge Neon anyone know why
JOHN EDVON
Air Conditioning problem
1999 Dodge Neon 4 cyl Two Wheel Drive Automatic
my 99 sohc ac works fo a minute then gets hot, so i thought get a little 134 and all would be well, not so, seems when the car is cool (first start up) the pressure on the low side is normal and the air is cold, after running a few minutes the low pressure, cold line gets hot and the pressure goes off the scale?? what could be causing this??
May 11, 2008 at 2:46 PM
  • 31,937 POSTS
Hi there,
you may have an internal leak between th high & low sides in the compressor, get it checked out.
Mark (mhpautos)
May 11, 2008 at 5:01 PM
