1999 Dodge Neon Antifreez leak
1999 DODGE NEON
ANTHONYHIL
1999 Dodge Neon 4 cyl Front Wheel Drive Automatic
I have a 1999 doge neon and i put some antifreez in it today and when i wen't back out to the car later that day there was no antifreez there.So can you tell me what i should check so i'll no what to get fixed?
Nov 15, 2008 at 4:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Is the coolant underneath your car? You mean the coolant leaked out without the vehicle running? This is probably due to a hole in one of the radiator hoses, a faulty water pump, or cracked radiator. Inspect hoses for any cracks/holes or loose fittings. Check to see if coolant is dripping from water pump area.
Nov 15, 2008 at 5:03 PM
