1999 Dodge Neon
83,000 MILES • 4 CYL • FWD • AUTOMATIC
HANKNATOLI
engine stalls won't start no odbII codes
Aug 2, 2009 at 3:45 AM
BMRFIXIT
  • 19,053 POSTS
Check for SYNC
suspect crank sensor
Aug 9, 2009 at 12:24 AM
HANKNATOLI
Yes, I've looked at that, can the sensor work inter-mitent ? Can I bench test the sensor ?
Aug 9, 2009 at 2:14 AM
BMRFIXIT
  • 19,053 POSTS
very common for it to start when cool and stalls when heated up
after its stalls check if you have crank signal
using a scanner check for RPM reading when cranking
if you have rpm reading then its not the crank sensor if no reading sensor NO good
Aug 9, 2009 at 11:51 AM
