Yes, I've looked at that, can the sensor work inter-mitent ? Can I bench test the sensor ?
Aug 9, 2009 at 2:14 AM
BMRFIXIT
✓Experienced Mechanic
very common for it to start when cool and stalls when heated up
after its stalls check if you have crank signal
using a scanner check for RPM reading when cranking
if you have rpm reading then its not the crank sensor if no reading sensor NO good
