HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Neon
Drivetrain
Transfer Case
SPONSORED LINKS
1998 Dodge Neon Torque Specs
DODGESUX
MEMBER
1998 DODGE NEON
Engine Mechanical problem
1998 Dodge Neon 4 cyl Front Wheel Drive Automatic 133*** miles
I need the torque specs for the head on a 2.0 SOHC engine on a dodge neon if anybody has it please.
Saturday, March 1st, 2008 AT 7:35 PM
BMRFIXIT
MECHANIC
Cylinder head bolts 4 steps
125Ft. Lbs
250Ft. Lbs
350Ft. Lbs
4additional 90*
that’s last step is 90 degree and NOT ft. Lbs
good luck
let me know
SPONSORED LINKS
Saturday, March 1st, 2008 AT 7:47 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
2003 Dodge Neon I Just Have No Idea
2003 Dodge Neon 4 Cyl Two Wheel Drive Automatic A Lot Miles My Car Is Soo Broke! Some Day In November, I Would Say, As I Went To Start...
Asked by
tabathalane
2003
DODGE NEON
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
2003 Dodge Neon
2003 Dodge Neon 4 Cyl Front Wheel Drive Automatic 80.000 Miles My Driver Side Wipper Workes An Passanger Side Every Once In A While. Why...
Asked by
jon_an_3
2003
DODGE NEON
2003 Dodge Neon
Computer Problem 2003 Dodge Neon 4 Cyl Two Wheel Drive Automatic Want To Know About Computer For This Car
Asked by
marsha brooks
1 ANSWER
2003
DODGE NEON
1997 Dodge Neon Fuel Accumulator
Engine Mechanical Problem 1997 Dodge Neon 4 Cyl Front Wheel Drive Automatic What Is The Fuel Accumulator On A 97 Dodge Neon And Where...
Asked by
slnsln171
1 ANSWER
1997
DODGE NEON
1995 Dodge Neon Cv Joint Or Wheel Bearings?
The Car Has A Grinding Noise In The Right Front. I Removed The Half Shaft, And The Inner Joint Seems Fine, But The Outer Joint Doesn't...
Asked by
JBingham
1 ANSWER
1995
DODGE NEON
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Clutch Not Working
How to Service the Transmission
Online car repair manuals
