1998 Dodge Neon timeing belt
NYLAUHL
  • 1998 DODGE NEON
  • 4 CYL
  • FWD
  • 123,000 MILES
The damper will not come off.
i did everything the book said to do.
the damper wont come off the crank shaft.
help
Sunday, November 30th, 2008 AT 12:00 PM
DOCFIXIT
  • 18,828 POSTS
Got the crank bolt out pully puller on good and tight. Now take hammer smite the end of bolt on puller. It will pop loose alaso a little heat meybe needed.
Sunday, November 30th, 2008 AT 4:05 PM
BMRFIXIT
  • 19,053 POSTS
It require a special 3 jaw pulley
with a long insert to go where the center bolts is
check with your rent tool center for it
any thing else will damage the damper pulley
Monday, December 1st, 2008 AT 6:43 AM
