1998 Dodge Neon Steering rack leaking
135,000 MILES • 4 CYL • FWD • AUTOMATIC
DSGURR
The steering rack on this vehicle suddenly started leaking, draining all fluid in minutes. Refilling anf looking ander the vehicle it appears to be coming from the pressure switch. The lines are not leaking and the pump is fine. Is this common the pressure switch would fail and then leak all fluid. Would replacing the sensor solve it?
Aug 17, 2008 at 6:54 AM
BMRFIXIT
  • 19,053 POSTS
If the sensor is at fault and leaking ,replacing it for sure will help
you need to check where the leak is coming from .
Aug 17, 2008 at 11:28 PM
