1998 Dodge Neon shut off
90,000 MILES • 4 CYL • FWD • AUTOMATIC
SMRF2008
My 98 neon shuts off after ten fifteen minutes of driving. It seems as soon as the engine warms up its shuts off. I wait for it to cool down for about fifteen minutes and starts back up again. Then it dies again. I changed the coil pack and it still dies. A mechanic told me that it was the crank position sensor but not sure. I heard that it could also be the auto shut off rela.
Aug 14, 2008 at 6:34 AM
POET042005
  • 134 POSTS
well there is a very good chance that if theres a bad sensor then the check engine lite is on so guess my question is if its on or not and if so have you checked for codes thats where you wanna start.
It does sound like a sensor problem possibly crank, this is a common problem with many cars in general.
let me know RICH.
Aug 15, 2008 at 1:46 AM
SMRF2008
The check engine light went on once but turned off. They put the computer to see if there is something wrong but it showed nothing. Thats why i dont know what is wrong.
Aug 16, 2008 at 7:58 AM
POET042005
  • 134 POSTS
Your next step may be to check the feul pressure. I have seen this happen with a feul tank that had trash in it, or a faulty feul pump or pressure regulator
fuel pressure specification is 48 PSI
Aug 17, 2008 at 3:49 PM
BMRFIXIT
  • 19,053 POSTS
Two things I would check
1. crankshaft sensor
2. ASD relay
good luck
Aug 17, 2008 at 11:21 PM
SMRF2008
They replaced the crankshaft sensor and it still dies. Now the machanic says that the ecm is bad. He hasn't checked the fuel pressure but will soon. If the ecm is bad wont the check engine light definetly be on?
Aug 18, 2008 at 10:55 AM
BMRFIXIT
  • 19,053 POSTS
check fuel pressure for sure
ask them to check also ASD RELAY AND IGNITION SWITCH and its wiring
PCM very rare for it to fail
Aug 18, 2008 at 2:11 PM
SMRF2008
does the ecm control the radiator fan? They don't seem to be working. Would the car shut off if the fans don't turn on? It seems like as soon as the car reaches its normal operating temp thats when it shuts off.
Aug 19, 2008 at 5:42 PM
BMRFIXIT
  • 19,053 POSTS
PCM (ecm)
is the brain all go through it !!
turn AC on check fan
if the car overheating and fan not coming on then it shut off .
U NEED TO CHECK IT AFTER IT SHUT OFF ON U !!!
check for fuel and fuel pressure
check for spark
check injector pulse
Aug 19, 2008 at 11:23 PM
