1998 Dodge Neon rough idle, engine codes
REDTEG90
1998 Dodge Neon 4 cyl Front Wheel Drive
car runs really rough at idle, even stalls a lot when its hot out. smoothes out when driving. had codes read and got cylinder 4 misfire {just replaced plus and wires, checked that number 4 is firing} downstream o2 sensor, cam position sensor, egr flow. is it likely one problem causing other codes. if so where should i start
Jun 13, 2010 at 4:30 AM
  • 75,988 POSTS
P0304
Check cylinder no.4 compression and injector
Jun 13, 2010 at 9:50 AM
