1998 Dodge Neon Rear Suspension Problem
KSTUDLEY
Suspension problem
1998 Dodge Neon 4 cyl Front Wheel Drive Automatic
My sister was given a 1998 Dodge Neon, the two rear tires are bowing in at the top. What is the most likely cause, as I believe it may be the axle. Also I would need a good diagram of the axle assembly if it is the axle so I can email it to her.
May 23, 2008 at 7:32 AM
MERLIN2021
  • 17,250 POSTS
Most likley cause is it needs an all four wheel alignment! And or the springs need to be replaced, is it sagging in back?
May 23, 2008 at 7:37 AM
KSTUDLEY
[quote:c4d378d3dc="merlin2021"]Most likley cause is it needs an all four wheel alignment! And or the springs need to be replaced, is it sagging in back?[/quote:c4d378d3dc]
From what I understand it does not sag in the back, the rear tires on both sides are bowing towards the cabin.
May 23, 2008 at 7:42 AM
MERLIN2021
  • 17,250 POSTS
Needs an alignment, a four wheel alignment...maybe if all parts are OK 100.00 dollars...
May 23, 2008 at 7:46 AM
