I have no idea how to drain my radiator and add antifreeze. Where's the plug?? Help! Thanks
Jan 10, 2010 at 9:50 AM
✓Experienced Mechanic
REMOVAL:
Draincock
1.Turn the drain cock stem counterclockwise to unscrew the stem. When the stem is unscrewed to the end of the threads, pull the stem from the radiator tank.
INSTALLATION:
1.Push the draincock assembly body into the tank opening.
2.Tighten the drain cock stem by turning clockwise to 2.0 - 2.7 Nm (18 - 25 inch lbs.) .
