Check operations of your hazard lights and turn signals on ALL four corners. If all of them are blinking normally, check fuse #20, inside power distribution center under the hood. If fuse is good, Get access to turn signal/hazard switch wiring harness. With the brake pedal pushed down, check continuity between #2 (white/tan wire) and #3 (brown/red). Also continuity between #2 (white/tan wire) and #9 (dark green/red).
Is there continuity? YES: Go to next. NO: Replace turn signal/hazard switch.
Mar 26, 2021 at 3:24 AM
