Son's car,the timing belt tensioner went out replaced the belt,tensioner and h2o pump. talked to the previous owner's machanic about this car, he states that at one time the overhead cam cover bolts were lose when the car lost power and wouldn't pull itself. He tightened up the cam bolts and power was restored. Now after about another 60,000 miles has passed, no power and runs very rough, not firing on #1 ( still have strong spark through the plug), took it to a machanic ,failed a compresion test ( just on #1 other 3 were ok, No water in the oil no white smoke from tail pipe). What is the likely hood that it is a problem with the cam like before or a headgasket?,
Oct 2, 2008 at 8:59 AM
