1998 Dodge Neon ice in gas line
1998 DODGE NEON
102,577 MILES • 6 CYL • FWD • AUTOMATIC
ELMO JAMES
how do i get ice out of the gas line? I put some stp gas treatment in and let it set over night, tried it this morning still will not start!. Please help! winter blues
Feb 13, 2008 at 2:59 AM
BMRFIXIT
  • 19,053 POSTS
[quote:c5a525eb34="elmo james"]Other Category problem
1998 Dodge Neon 6 cyl Front Wheel Drive Automatic 102577 miles
how do i get ice out of the gas line? I put some stp gas treatment in and let it set over night, tried it this morning still will not start!. Please help! winter blues[/quote:c5a525eb34]
Are you sure the reason for no start is water in the tank
make sure and if so you should drain the tank and fill it with fresh fuel
check spark and if you have fuel pressure
you can add dry gas to the tank
good luck
Feb 13, 2008 at 11:00 AM
