Hello, I'd check trouble codes. You may be able to get some codes by cycling the ignition switch. You just cycle the key to the on position, you don't crank it, cycle on--off, on--off, on. Then the cel starts flashing, you count the flashes to get the codes.
SPONSORED LINKS
Thursday, July 30th, 2009 AT 10:12 AM
