1998 Dodge Neon Front Crank Pulley
TURTLE4107
Engine Mechanical problem
1998 Dodge Neon 4 cyl Front Wheel Drive Automatic
How do I get the front crank pulley off? I have the crank pulley tool, the pulley just ain't backing off the crank. I been trying for the last 3 days, somebody mentioned to me to heat it up with a torch but I don't want to damage anything
Sep 10, 2008 at 1:03 AM
2CARPRO JACK
  • 11,533 POSTS
Do you have the exact puller for those engines? The correct puller has a long rod that goes into the snout of the crank, if yours doesnt have this, then you are trying to pull against the center of the crank pulley.
Sep 10, 2008 at 1:15 AM
