1998 Dodge Neon Engine Problem
94,700 MILES • 4 CYL • FWD • AUTOMATIC
WANDA523
I have a 98 dodge neon with 94,700 miles. I have a "check engine" light on. I went to hit my alarm on my car and didnt go off..went to start the car and didnt start. My husband thought maybe the battery was dead but i just put in a brand new battery in about 3 weeks ago. So, he jumped the battery and the car started up. I let it run for a few minutes..shut it off and started it up again and it worked, however i noticed i had to give it gas when i was turning the key. My husband took the battery out and reconnected it and the "check engine" light went away! Then about 5-6 days later, i went out to my car to go to work and the same thing happened. I hit the alarm and it didnt go off so i knew right away that it was the same problem again. When my husband went and put the jumper cable on my car and connected it to his car, my lights and alarm came back on without me even starting the car. I then started the car up and it worked. I asked my mechanic and he said my battery and alternater were both fine from a test he did. What could be causing my car to not start every few days or so?
May 21, 2008 at 2:21 AM
BMRFIXIT
  • 19,053 POSTS
something staying on ,draining the battery
ask your, mechanic to do a draw test on the battery
that should help detecting the problem
check if any door lock actuator sticking
May 22, 2008 at 10:26 AM
