1998 Dodge Neon engine
4 CYL • FWD • AUTOMATIC
ANDREW RIVERA
  • 34 POSTS
what kind of liquid can i use to clean out the engine block inside like where the oil passes through. in my car i have low oil presure and ive tryed everything to get it up and everything failed.how do the piston rings go on these pistons.
May 20, 2010 at 11:58 AM
  • 31,937 POSTS
Hi there,
There are good quality engine oil flushes, they do work well, you can also run a mix of diesel and engine oil as well, but caution must be taken when doing this as bearing failure can result if the engine loads are to great, i would stick to the commercial products, the rings are fitted into machined groves in the pistons.
Mark (mhpautos)
May 20, 2010 at 2:49 PM
