1998 Dodge Neon Car was running fine, left if parked for tw
1998 DODGE NEON
117,000 MILES • 4 CYL • 2WD • AUTOMATIC
JCNEWTON
My car was running fine, I recently changed spark plugs. Regular oil change.
I had to leave town for 2 weeks. Left it parked, when I got back, I tried starting it and it won't start.
I checked the battery, even jumped it just to make sure and seems ok.
Checked sparks and there is a spark being generated. Checked fuel line, gas is flowing through it. Took out fuel injectors and there is gas spraying out. Not much but there is gas coming out. How much should come out of these?
What else could be the problem?
Jun 10, 2010 at 7:35 AM
Your fuel pressure should be 49psi with key on
Check the fuel pressure with a guage to verify if its within specs and then get back with the readings
Jun 10, 2010 at 11:43 AM
