1998 Dodge Neon blower motor
133,000 MILES • 4 CYL • FWD • AUTOMATIC
FRANMATTER
How to replace the blower motor
Oct 27, 2010 at 11:54 AM
SATURNTECH9
  • 30,869 POSTS
The blower motor is located on the bottom right side of the unit housing. The blower motor can be removed from the vehicle without having to remove the unit housing assembly.
REMOVAL
Remove right side scuff plate.
Pull back carpet.
Cut wheel housing silencer in line with blower motor wiring.
Disconnect blower motor wiring connector.
RHD vehicle remove the motor cover.
Blower Motor Retaining Screws
Remove three blower motor retaining screws.
Lower blower motor assembly from unit housing.
INSTALLATION
For installation, reverse the above procedures. Then tape silencer into position.
There you go.
Oct 27, 2010 at 12:23 PM
