1997 Dodge Neon wont start
160,000 MILES • 4 CYL • 2WD • MANUAL
STRAP29
I have a 97 dodge neon the other day I started the car to warm it up I came outside and it was not running. I tried to start it again and it wouldnt start. that was a week ago. Since then I have replaced the fuel pump the fuel rail and the injectors. It still wont fire. I dont know if its good to pull the fuel rail out and try to start it but I did and no fuel would come out of the injectors. I also replaced the plugs and wires. Do you have any idea why it wont fire Thank You .
Feb 17, 2008 at 10:21 AM
BMRFIXIT
  • 19,053 POSTS
did you check if you have spark @ the wires
i would check that
check timing belt
check /replace crank sensor
ASD relay should be checked too
start with the spark test 1st
good luck
Feb 19, 2008 at 3:51 AM
