1997 Dodge Neon relays and pcm
177,000 MILES • 4 CYL • FWD • AUTOMATIC
EDWARD CD
can a PCM work spratically, can a relay work spratically.
how can you tell is a relay is bad. I have already tried connecting a small battery to it and it trips the circuit.
I forgot to add that after changing the crank sensor it ran after giving it a jump because the battery was dead I turned it off and it restarted it again and it ran. But when I pulled the old battery out that night and repalced it with a new one the next day it would not start. Any ideas?
Thanks for any help
This is a great site
Aug 19, 2008 at 11:00 AM
BMRFIXIT
  • 19,053 POSTS
check fuses
check alarm system
check for fuel
check for apark injector pulse
what is missing
Aug 19, 2008 at 11:29 PM
