1997 Dodge Neon over heats at idle
124,000 MILES • 4 CYL • FWD • AUTOMATIC
RAY.B
my old engine over heated blew a head gasket and i got another engine with 40,000 miles on it put it in
and engine still over heats...could it be a clogged radiator? with other engine we had put stop leak in
several times! if it is can i get the stop leak out and how? has new waterpump, t/stat andhoses.
please help.
ray b.
Jun 12, 2008 at 4:01 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:4a95934aba="ray.b"]Engine Cooling problem
1997 Dodge Neon 4 cyl Front Wheel Drive Automatic 124000 miles
please help.
ray b.[/quote:4a95934aba]
It is possible tha you clogged the radiator with stop leak... You would have to replace it....
Now does the cooling fan work?
Jun 12, 2008 at 8:31 AM
RAY.B
the fans work great!
what happens is while idle it overheats the while giving gas it goes down!
same goes while i drive the car, any help would be great.
thanks , ray b
Jun 12, 2008 at 10:04 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:497ef10b71="ray.b"]the fans work great!
thanks , ray b[/quote:497ef10b71]
OK, is the radiator boiling over or is the gauge showing over heating? If it is the guage that is showing over heating if you can either with a scan tool that can monitor the engine sensors or an infared heat gun check the actual engine temp.
If the temp is normal then you most likely have a short somewere.
Jun 12, 2008 at 11:42 AM
RAY.B
it was the radiator ...got a new one and pow; its fixed.
thanks to obxautomedic that helped
ray b
Jun 28, 2008 at 3:57 AM
