1997 Dodge Neon low oil pressure light
1997 DODGE NEON
93,000 MILES • 4 CYL • FWD • MANUAL
JSMITH3472
Yes I was driving my 97 neon home from work and engine just cutoff on me, no idleing down or anything just cutoff. only light thats on is oil light, did complete oil change, lights still on engine turns but wont start whats the problem?
Sep 10, 2010 at 12:33 AM
engine turns but wont start whats the problem? Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Sep 10, 2010 at 12:51 AM
JSMITH3472
Did the spark plug test no blue spark. Checked codes got a code 12 and code 54 going to replace camshaft position sensor tommorrow. Any suggestion if that doesnt work. Also changed coil pack
[quote:beb92b814a="rasmataz"]engine turns but wont start whats the problem? Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing[/quote:beb92b814a]
Sep 12, 2010 at 7:43 AM
Check and test the rest of the ignition components
Sep 12, 2010 at 8:58 AM
