1997 Dodge Neon Knocking Noise
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
GIMIS
Recently replaced exhaust manifold, and did some minor repair to the wiring harness and exhaust pipe. I went on a short drive to go do a drive cycle, so I can get the car smogged, when I started to hear a really loud knocking sound from the engine. The sound gets louder and faster the higher the RPM's rev. When the car goes to 50-60 (I had to return on the freeway from whence I came) the knocking sound cuts on and off, a few knocks here, no knocking there. Between 0-40 mph the sound in constant and loud. I read that it was prolly a thrown rod or blown bearing. I tried removing the spark plugs on each cylinder to see if there was any change in the sound and there was not.
Oct 25, 2010 at 12:47 PM
  • 75,988 POSTS
Rod bearing noise makes a thudding noise, main makes a thumping noise
Sounds like a rod bearing-to ID what rod -pull the plug wire one at time while the engine is idling the one that lessen the noise is the culprit area
Oct 25, 2010 at 9:26 PM
GIMIS
[quote:eafcd6bf62="rasmataz"]Rod bearing noise makes a thudding noise, main makes a thumping noise
Sounds like a rod bearing-to ID what rod -pull the plug wire one at time while the engine is idling the one that lessen the noise is the culprit area[/quote:eafcd6bf62]
i just tested this, turned the car on to idle, pulled each wire off the plugs one at a time, the noise cut on and off while i was pulling wires, but no specific change in the sound on any one wire
Oct 26, 2010 at 5:18 AM
