1997 Dodge Neon idling high and pushing blue smoke
1997 DODGE NEON
136,000 MILES • 4 CYL • FWD • MANUAL
DALEAJAS
my car is idling at 5000 rpms when i start it then drops if i put it in neutrual and pump the clutch and is pushing blue smoke EGR code was given off If i fix the egr will this solve the problem or is there a bigger issue could the blue smoke be a piston ring problem?
Feb 28, 2008 at 2:57 PM
LEGITIMATE007
  • 5,121 POSTS
yes it could be a piston ring problem or valve seals. how bad is the blue smoke?
Feb 28, 2008 at 3:25 PM
