1997 Dodge Neon Fuses blowing in fuse box under hood
239,456 MILES • 4 CYL • FWD • AUTOMATIC
ISMJ24
I have a 1997 Dodge Neon about two months ago I replaced the fuel pump and since then the car has had like a hiccup to it everynow and then. THe car will cutoff and all of sudden catch right back up like it hasn't cut off at all. Well today it cut off and did't cut back on. We took the fuel pump out and tested it and it works. THe only thing we can figure out is thet it is blowing the fuses underneath the hood of the car. Does anybody have any suggestions to what the problem may be?
Feb 26, 2008 at 11:13 AM
BMRFIXIT
  • 19,053 POSTS
check the wiring---- relay--- and the pump plug and if all OK replace fuel pump module
Feb 27, 2008 at 8:33 AM
