1997 Dodge Neon crank seal
SJJDIXON8
Engine Mechanical problem
1997 Dodge Neon 4 cyl Front Wheel Drive Automatic
does anyone have or know where there is a site for how to change crank seal in my neon? thank you. Jeremy- Vermont
Jan 2, 2009 at 12:46 PM
VIPERTEK
  • 40 POSTS
there are 2 front and rear. the rear seal ..you need to remove the transmission. I would highly suggest you make sure it is your crank seal .. Most common causes of oil leaks are valve covers and head gaskets on that model. Chrysler has updated head gaskets for you car,they know about the problem.
Jan 9, 2009 at 1:30 AM
