1997 Dodge Neon Anti-freeze leaking
MEINDERS
  • 7 POSTS
Heater problem
1997 Dodge Neon 4 cyl Front Wheel Drive Automatic
1997 deon sport, leaking anti-freeze above area of oil pan
Dec 10, 2008 at 9:36 AM
ZACKMAN
  • 4,202 POSTS
Bad water pump, leaking from weep hole.
Dec 10, 2008 at 3:58 PM
MEINDERS
  • 7 POSTS
[quote:b8ca63b3ee="meinders"]Heater problem
1997 deon sport, leaking anti-freeze above area of oil pan[/quote:b8ca63b3ee]
Dec 11, 2008 at 11:03 AM
MEINDERS
  • 7 POSTS
How much will cost to repair water pump?
Dec 13, 2008 at 6:11 AM
ZACKMAN
  • 4,202 POSTS
If you purchase the parts it will be about $90, water pump $40 and timing belt $44 (DOHC) or $41 (SOHC), plus tax, and it lists 4.5 hours to remove and install w/p and timing belt at the same time. You have to remove timing belt to remove the water pump, you may as well replace the belt. I can't tell how much labor, it varies with localities, so call around your local shops, find out what kind of rate they have times 4.5.
Dec 14, 2008 at 5:27 AM
