1997 Dodge Neon Anti-freeze leaking
MEINDERS
  • 1997 DODGE NEON
Heater problem
1997 Dodge Neon 4 cyl Front Wheel Drive Automatic
1997 deon sport, leaking anti-freeze above area of oil pan
Wednesday, December 10th, 2008 AT 5:36 PM
ZACKMAN
  • 4,202 POSTS
Bad water pump, leaking from weep hole.
Wednesday, December 10th, 2008 AT 11:58 PM
MEINDERS
  • 7 POSTS
Thursday, December 11th, 2008 AT 7:03 PM
MEINDERS
  • 7 POSTS
How much will cost to repair water pump?
Saturday, December 13th, 2008 AT 2:11 PM
ZACKMAN
  • 4,202 POSTS
If you purchase the parts it will be about $90, water pump $40 and timing belt $44 (DOHC) or $41 (SOHC), plus tax, and it lists 4.5 hours to remove and install w/p and timing belt at the same time. You have to remove timing belt to remove the water pump, you may as well replace the belt. I can't tell how much labor, it varies with localities, so call around your local shops, find out what kind of rate they have times 4.5.
Sunday, December 14th, 2008 AT 1:27 PM
