1997 Dodge Neon
BENBLACKBURN
1997 Dodge Neon 150000 miles
I have a 1997 dodge neon with an engine ping that shows up afte the car has been driven for over 20minutes. What would be the most likely causes? (I read the spark plugs and the engine may be running on the lean side.)
Mar 15, 2008 at 2:50 PM
BMRFIXIT
  • 19,053 POSTS
check tune up make sure you have the correct spark plugs
try to use a higher octane gas
check timing belt
Mar 16, 2008 at 4:19 AM
