HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Neon
Engine
Timing Belt
Replace/Remove
SPONSORED LINKS
1996 Dodge Neon timing belt assembly pivot Bolt
DWHOL6044
MEMBER
1996 DODGE NEON
Engine Performance problem
1996 Dodge Neon 4 cyl Two Wheel Drive Automatic
Need to know what would be the torque for the timing belt pivot assembly bolt. The bolt back out upon removal.
Saturday, February 21st, 2009 AT 5:06 PM
OBXAUTOMEDIC
MECHANIC
The Torque is 23 ft lbs
SPONSORED LINKS
Saturday, February 21st, 2009 AT 6:40 PM
Please
login
or
register
to post a reply.
Related Timing Belt Replace/Remove Content
Replace Timing Belt And Water Pump?
Hello, I Recently Purchased A 1998 Dodge Neon Coupe. It Has The 2.0 Litre Dohc Motor. When I Bought It Used It Had 67,108 Miles On It, And...
Asked by
Staplesa
DODGE NEON
Engine Miss After Replacing Timing Belt
After Replacing Broken Timing Belt, Engine Starts Up And No "check Engine Light". However Engine Has A Miss While At Idle. At Around 3000...
Asked by
n8nathan8
2005
DODGE NEON
I Changed My Timing Belt But Why Does My Car Not Hold...
I Purchased A Used Vehicle For About 300$ Knowing That I Had To Fix A Timing Belt Issue. While Making The Repairs I Discovered That The...
Asked by
Kitomei
1 ANSWER
2000
DODGE NEON
1997 Dodge Neon Replaced Timing Belt & Water Pump...
Last Week I Was Driving Down The Interstate In My 1997 Dodge Neon And The Car Just Died And I Had To Pull Off To The Side Of The Interstate...
Asked by
lyndonboy
1 ANSWER
1997
DODGE NEON
2000 Dodge Neon Replaced Timing Belt
Replaced Timing Belt & Camshaft Position Sensor. And The Car Still Won't Start. Please Help Me?
Asked by
angelfaith888
1 ANSWER
2000
DODGE NEON
VIEW MORE
SPONSORED LINKS
Serpentine Belt Replacement Chrysler
Serpentine Belt Replacement Chevrolet Tahoe
Engine Not Starting
Online car repair manuals
