1996 Dodge Neon Spark Plug and Knocking
DIZZY258
Engine Mechanical problem
1996 Dodge Neon 4 cyl Front Wheel Drive Manual
Hello, I have a 96 dodge Neon, 5speed, sohc, and I found oil in the spark plugs. Also, when I step on the gas, the car knocks, and stutters, and I cannot accelerate like I use to. I was told it was the cat converter, and when I replaced it, it still continued. Then I was told it was because I was driving with only 3 spark plugs instead of 4. But it still continued. now I'm am hearing it may be my valve cover gasket, or a head gasket, or a bad intake manifold. can you help me out??
Feb 26, 2010 at 7:13 AM
SCOTTY DEE
  • 592 POSTS
The oil on the spark plugs is coming up past the piston rings and into the combustion chamber. If they were oil fouled, you may be getting a spark knock or "ping" as opposed to an engine mechanical knock.
Does the cylinder head gasket leak oil? Most all of them do at some point. I assume you have been getting your information from a repair facility?
Feb 26, 2010 at 8:07 AM
