1996 Dodge Neon Shifts early
108 MILES • 4 CYL • AWD • AUTOMATIC
SIMPLEMAN01
I have a neon. It has been sitting for 3 years and I replaced the head on it and egr and it runs great but when I drive it shifts early when you have the pedal down all the way 2500rpm every time but if i shift it manually I can get it to rev out or over 2500. I can free rev it high too. No codes are pulled. I can't figure out what is wrong with it. I need help. Thank you
Dec 30, 2008 at 1:48 PM
VIPERTEK
  • 40 POSTS
there is an adjustment for that ...but if it has been sitting good possability that the linkage is froze up on selector shaft on tran. if it is a 3 speed trans. Go to front of trans there are 2 cables that go there the top 1 is your kick down cable that controls upshift and down shift....try to move it back and forth..also has a return spring connected to it dont take the e-clip off of the shaft ,or you will need to take out the valve body. You can use a lube and work it back and forth to free it up, remember it is top cable ...bottom cable is gear select. good luck
Jan 9, 2009 at 1:18 AM
