Wonder if you could help with this. I keep getting a service engine soon light, and the diagnosis says a misfire on cylinder 2. This has happened about 3 times within the last two months. The coil pack has been changed, the spark plugs changed, wires changes. The initial problem started because oil was getting on the plugs. This last time however, no oil can be found. I do drive the car a lot. What could be the continued cause of this problem? What type of servicing should be done, and how much is reasonable to pay a good mechanic to have the problem fixed? Thanks you so much for your time and attention
Mar 5, 2009 at 12:21 PM
