1996 Dodge Neon no spark
PHILJAFO12
Electrical problem
1996 Dodge Neon 4 cyl Front Wheel Drive Automatic
i replaced the head gasket and had the car started it ran good for about 3 min and then it just stopped. The coil pack has in tolerance resistance measurments and i replaced the cam position sensor and the crank position sensor i get no dtc's from the computer when checked w/scan tool and here is a list of the live data it gives w/the key on but not cranking as the scan tool wont read while cranking
fuel sys 1 ol
calc load% 0
ect 86
STFT B1 0
LTFT B1 0
MAP 28.9
ENG RPM 0
VEH SPEED 0
SPARK ADV 0
IAT 84
TPS% 12.1
O2S B1 S1 .470
STFT B1S1 0
O2S B1S2 .470
STFT B1 S2 NA
Aug 18, 2008 at 10:13 AM
BMRFIXIT
  • 19,053 POSTS
recheck the timing belt
do u have RPM reading when cranking
check the crank sensor
check fuses and relays
recheck all connectors and grounds
Aug 18, 2008 at 2:19 PM
