1996 Dodge Neon locked brake
70,000 MILES • 4 CYL • FWD • AUTOMATIC
GWRISINGER
front driver side brake wont release unless bleeder valve is opened
Jun 4, 2009 at 3:41 AM
CARADIODOC
  • 34,391 POSTS
Dandy observation about the bleeder screw. Use a channel-lock pliers to open the crimp just a little where the bracket is crimped around the center of the rubber hose. Rust builds up inside and constricts the hose. You'll force enough fluid through to apply the brake, but the trapped fluid will take a long time to release.
caradiodoc
Mar 11, 2021 at 6:01 AM
