1996 Dodge Neon keeps blowing ignition fuse
150,000 MILES • 4 CYL • FWD • AUTOMATIC
1996NEON
i have a 1996 dodge neon that keeps blowing the ignition fuse(the #10 fuse thats inside the car not under the hood). i have replaced the fuse multiple times. i let the car idle for about 10 minutes and then drove about a mile and a fuse blew. it took 4 fuses to get me back home that one mile
Jan 25, 2009 at 4:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You will probably need to replace your starter. You can have your starter tested first before replacing but this normally happens because the starter draws to many Amps of electricity due to age, amount of use etc..
Thanks for using 2CarPros.com!
Jan 25, 2009 at 4:56 PM
1996NEON
i had the starter tested today and advanced auto parts said it was running just fine..thank you for the suggestion, any more help will be greatly appreciated
Feb 12, 2009 at 6:09 AM
1996NEON
i replaced the starter today upon further review..that didnt fix the problem so any more help would be great
Feb 12, 2009 at 12:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Inspect the wiring running from ignition. Ensure no bare wires are grounding and use a meter to test wires for any shorts.
Feb 12, 2009 at 4:10 PM
1996NEON
what kind of meter do i need to test for shorts and whats the procedure to do that? do you mean the ignition itself?
Feb 25, 2009 at 1:11 PM
