1996 Dodge Neon i can't pass emissions
1996 DODGE NEON
83,000 MILES • 4 CYL • FWD • MANUAL
CCCH510
my neon is failing emissions by 5x the limit on co and 2x the limit on hc. i have replaced the evap canister the map sensor the iat sensor the computer the injectors and the exhaust recycle system is running fine. how else can i be failing that bad?
Apr 14, 2008 at 2:01 AM
BMRFIXIT
  • 19,053 POSTS
you need to check for codes
do you have check engine light on
and if so scan the system for codes
let me know
Apr 14, 2008 at 6:25 AM
CCCH510
I don't have any codes that is what is bothering me about the engine
Apr 14, 2008 at 7:21 PM
BMRFIXIT
  • 19,053 POSTS
for the readings to be that high the O2 sensor should pick it up
unless its no good
with key on engine off you have check engine light on
I still think you should have it scanned
Apr 14, 2008 at 8:00 PM
