1996 Dodge Neon how to remove the harmonic balancer pulley
1996 DODGE NEON
20DORY20
  • 5 POSTS
Engine Mechanical problem
1996 Dodge Neon 4 cyl Two Wheel Drive Automatic
We have used the 3 prong puller but it wasn't budging and now it seized up. Is there something that needs to be removed before or are we using the wrong kind of puller?
Jul 26, 2008 at 4:35 AM
DOCFIXIT
  • 18,828 POSTS
Did you remove the big crankshaft bolt?
Jul 26, 2008 at 4:50 AM
20DORY20
  • 5 POSTS
Yes we did.
Jul 26, 2008 at 6:36 AM
DOCFIXIT
  • 18,828 POSTS
Make sure the screw jack is not in interference with the balancer . so get a good pull even on all three bolts then tap the top of the screw jack. Sometimes it maybe necessary to heat the center of balancer.
Good luck
Jul 26, 2008 at 6:58 AM
DOCFIXIT
  • 18,828 POSTS
When you say three prong pull does this thing have arms and hook around the outside of balancer?
If so wrong puller you need an harmonic puller it bolts to balancer in those bolt holes in the center. Auto Zone can rent , you will never get it off with a bearing puller.
Jul 26, 2008 at 7:26 AM
20DORY20
  • 5 POSTS
Yea we are using a 3 jaw puller, the only problem is the pulley doesn't have bolt holes.
https://images.2carpros.com/forum/automotive_pictures/218786_IMG_3425_1.jpg
Jul 26, 2008 at 7:40 AM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_puller_chry_2.jpg
Jul 26, 2008 at 7:44 AM
20DORY20
  • 5 POSTS
Thats exactly what we have and how we r doing it. Thanks
Jul 26, 2008 at 8:04 AM
20DORY20
  • 5 POSTS
we may have to try heating up the balancer
Jul 26, 2008 at 8:07 AM
BMRFIXIT
  • 19,053 POSTS
are using a rod in the center check the picture I sent it has a rod in where the center bolt was removed
and it longer then the bolt that was removed
Jul 26, 2008 at 12:31 PM
