1996 Dodge Neon gas tank
REDMAN122081573
1996 Dodge Neon
How would I drop the gas tank on my dodge neon so I can change the fuel filter?
Apr 1, 2009 at 7:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Do the following operations to replace your vehicles fuel filter...
REMOVAL:
Properly relieve the fuel system pressure.
If not done already, disconnect the negative battery cable.
Raise and safely support the vehicle.
Unfasten the quick-connect fuel supply line from the filter/regulator nipple.
Depress the locking spring tab, located on the side of the fuel filter/regulator, then rotate 30° and pull out. Make sure the upper and lower O-rings are still on the filter assembly.
INSTALLATION:
Lightly coat the filter O-rings with clean engine oil. Insert the filter into the opening in the fuel pump module, then align the 2 hold-down tabs with the flange.
While applying downward pressure, rotate the filter clockwise until the spring tab catches in the locating slot.
Attach the fuel line to the filter/regulator assembly.
Carefully lower the vehicle, then connect the negative battery cable.
You should not need to remove or drop the fuel tank to reach the filter..
Thanks for using 2CarPros.com!
Apr 1, 2009 at 2:05 PM
