1996 Dodge Neon fuel pessure is 52 psi
12,400 MILES • 4 CYL • 2WD • AUTOMATIC
ASHLEYW8
  • 5 POSTS
this is the dodge neon that dies at moving for about 20 feet but when the brske on at 2000 rpm it keeps funning
Sep 27, 2009 at 9:01 AM
BMRFIXIT
  • 19,053 POSTS
Check for a vacuum leaks
check for trouble codes
check and clean IAC valve
Sep 27, 2009 at 9:09 AM
ASHLEYW8
  • 5 POSTS
I have every on the list you gave me we have sending message to each other fo the last few weeks
updated:
there is no vacuum leaks we hook \hook up the snap on scaner no codes came up walk through all the program ( ok ) could it be the speed sensor located in the trans the manuel does no say any way to check it
Sep 27, 2009 at 10:06 AM
BMRFIXIT
  • 19,053 POSTS
using the scanner can you control the RPM
also using the scanner do a min RPM test
Sep 29, 2009 at 12:22 PM
