1996 Dodge Neon Frozen engine
RODGERSV
1996 Dodge Neon
how to thaw out a frozen engine and radiator that has only water in it and how long to wait until trying to start it
Jan 18, 2009 at 6:22 AM
TONE94SHADOW
  • 8 POSTS
you got to be kidding me.what possessed you to do that. ok you need a warm (heated) shop or garage push it inside and open up all that you can( Antifreeze system). i dont think you will though. anyway let it set for about a day to two the longer the better 2 days should be long enough.note that water expands when it freezes and there may already be damage done to the veh. because of this. after you thaw it out you want to do a pressure test and i hope you didn't damage the waterpump. Remember to turn it over by hand first and check for ice in the radiator and feel the engine if it is warm it is thawed out / if it is cold its not
Jan 26, 2009 at 11:05 AM
