Heater problem
1996 Dodge Neon Automatic 128, 00 miles
AC/HEATER WENT OUT AND ITS NOT THE FUSES, NOT SURE WHERE TO LOOK NEXT
Wednesday, August 11th, 2010 AT 9:07 PM
MECHANIC
What went out? Is it the blower motor or what
SPONSORED LINKS
Thursday, August 12th, 2010 AT 4:20 AM
TAMMY52
MEMBER
Checked fuses for ac/blower fan heater/ defroster. Fuses ok and replaced. Is there a relay switch?
Saturday, August 14th, 2010 AT 11:25 PM
MECHANIC
There's no relay Could be the AC/Heater switch or the blower motor-find it and power the dark green wire at the motor from the battery positive post. At high position the blower motor will function w/o the resistor that's if the switch ground is good
