1996 Dodge Neon cooling fans
1996 DODGE NEON
62,000 MILES • 4 CYL • 2WD • AUTOMATIC
KENNYBENVENUTI
the radiator fans won't start. the engine runs very hot. if i pull the relay and plug it back in the fans start immediatly. i have exchanged the relays with the starter and the relay works with the starter and i have the same problem with the radiator fans.
thanks
kenny
Aug 25, 2010 at 12:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Need to test your vehicle's engine coolant temp. (ECT) sensor, this is the most likely fault.
Aug 25, 2010 at 1:12 PM
