1996 Dodge Neon Overheating
SRUE
I have a 96 dodge neon that seems to be overheating there is water in the radiator.no visable leaks.If it sets at idle it does not overheat for awhile only when i drive it.then it only takes about 7 minutes before it over heats. it is a 4 cyl. and has 100000 miles.head was replaced 3 years ago.water pump has never been replaced.it was leaking but we put a sealer in it.I was just wondering if it could be bad and not pumping like it should when you take off radiator cap the water seems to move but not very fast even at running tem.nothing is wrong with the thermostat
Jun 11, 2007 at 11:14 AM
SERVICE WRITER
  • 9,123 POSTS
The stop leak probably wasn't the best decision you have made, but I understand why people try it.
Sounds like the thermostat got gummed up and is staying closed or is blocked.
Jun 11, 2007 at 1:15 PM
Suggested Repair
Replace the thermostat. Stop-leak may have gummed it up so it stays closed or blocked, which would explain overheating under load despite coolant movement at idle.
Conversation Summary
A 1996 Dodge Neon with about 100,000 miles overheats after roughly seven minutes of driving but not while idling. Coolant is present with no visible leaks; the head was replaced three years ago, and stop-leak was used on a leaking water pump that was never replaced. The owner reports slow coolant movement with the radiator cap off and believes the thermostat is fine. The expert says stop-leak was a poor choice and that it likely gummed up the thermostat so it stays closed or blocked.
