1995 Dodge Neon Transmission Shift Issues
TJ62
i have a 1995 dodge neon 4 cylinder automatic trans. with about 150,000 miles on it.i bought the car after it sit for about 2 years with complaint of trans. fluid leaks out.i found a bent and leaking trans. pan so i replaced pan gasket and filter.car shifts fine from 1st to 2nd but will not shift to 3rd until it is warmed up good and i have to put shifter i neutral and raise rpms and put back in drive and it will shift to 3rd.trans. shifts from 3rd back to 1st at stop.when trans. is cold it will not shift to reverse unless you rev engine and then after a little while it slams into reverse.fluid is fine and no burned smell,what could be the ploblem and is there something i can do to repair myself ?
Nov 18, 2007 at 1:03 AM
CAR_GUY
DID YOU EVER GET THAT FIXED? i have a 1998 neon does the same thing now.
Jun 4, 2008 at 7:36 AM
  • 55,851 POSTS
It sounds like the filter has fallen out of its valve body which can make the transmission suck air, please check out the image below so you can see what I am talking about.
Jun 8, 2024 at 9:28 AM
Suggested Repair
Inspect the transmission filter and valve body. The filter may have fallen out of the valve body, allowing the transmission to suck air.
Conversation Summary
A 1995 Dodge Neon automatic with about 150,000 miles leaked fluid after sitting for two years. The owner replaced a bent pan, gasket, and filter. It shifts from first to second, but will not go into third until warm unless the shifter is moved to neutral and engine speed is raised. When cold, reverse engages only after revving and then slams in. Fluid looks fine and does not smell burned. An expert suggested the filter may have fallen out of the valve body, causing the transmission to suck air.
