Now it wont turn over, no click nothing
DERRICK_16
recently the car wouldn't turn over, so i tapped what the starter with my snow brush, and it sluggishly started. that worked for another 10 or 15 starts. now it wont turn over, no click nothing.... the gauges and dash lights all come on as usual but nothing happens when i try to start... any help?
Mar 23, 2009 at 7:39 AM
CARADIODOC
  • 34,414 POSTS
Have someone turn the ignition switch to "Crank" while you listen under the opened hood for a light click from the starter relay. If you don't hear it, suspect a possible neutral safety switch or shifter cable out of adjustment. Try starting it in neutral.
If you hear the relay click, there should be a loud clunk from the starter solenoid as it engages. If you get a single loud clunk but it doesn't crank, there's worn contacts in the solenoid. A rebuilt starter will solve this problem, but the contacts can be replaced for just a few bucks.
Try tapping on the starter while someone holds the ignition switch in Crank. If it eventually cranks, suspect rust buildup or hardened grease on the shaft the drive unit slides on. This is more common in cold weather. Clean the rust with a wire brush and re-lubricate it with a heavy oil or light grease.
You might try bypassing the starter relay by either removing its cover and squeezing the contact, or by removing the relay and using a paper clip or piece of wire to jump between the two terminals that for the letter "T". If it cranks consistently, you know the starter motor, solenoid, battery, and battery cables are good, and the problem is in the ignition switch / neutral safety switch circuit.
caradiodoc
Apr 15, 2021 at 12:00 PM
