1995 Dodge Neon voltage fluxuating
200,036 MILES • 4 CYL • FWD • AUTOMATIC
COREY D
car has a skip so i tested voltage and at the battery i am getting 10-19 volts when running. when i use the pos on the battery and ground at the frame i get 14.4 only once in a while i get 12.5 for a half sec. all of the grounds i cleaned and reattached that go to the battery on both ends. what would cause this?
Nov 10, 2008 at 9:24 AM
BMRFIXIT
  • 19,053 POSTS
Check for codes
codes will help point u in the right direction
suspect alternator
Nov 10, 2008 at 9:55 AM
COREY D
i checked no codes or gauge light. i am in the 12volt industry (car audio) and i have never seen anything test like this before.
Nov 10, 2008 at 10:39 AM
BMRFIXIT
  • 19,053 POSTS
This is why I asked for codes
this system is self diagnose and always running self check
I would suspect a bad ground
run a temp wire between battery negative side and alternator mount bolt
and recheck
Nov 10, 2008 at 12:48 PM
COREY D
i just got this car couple weeks ago but i added 0 gauge - battery to frame and frame to motor. i havent added alt pos to battery pos because i didnt have a metric nut on hand.
Nov 10, 2008 at 1:13 PM
BMRFIXIT
  • 19,053 POSTS
Run battery to motor with out the frame
Nov 10, 2008 at 1:25 PM
COREY D
well i replaced the alt today and in this car was a real pita. it didnt fix the problem come to find out the voltage regulator is in the PCM. i am going to have to find a used one. is it 95,96,97 the only yrs that will work?
Nov 11, 2008 at 11:23 AM
