1995 Dodge Neon Starting
ANAFLORANCE
Engine Mechanical problem
1995 Dodge Neon 4 cyl Two Wheel Drive Manual
I recently change the alternator in my car, and it has started since then. I have had the car looked over and tested. I have also replaced the ignition coil, and still have had no luck. The car will crank it just doesn't start. I need help please.
May 25, 2010 at 5:54 AM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 25, 2010 at 12:32 PM
